Speakers Help
Hey guys I am kinda new to the whole speakers scene and need some advice. I was wondering what you would recommend for decently cheap speakers with good quality. I am a beginner so I was wondering if you need to buy an amp to go with the speakers or not. Thank you
First youll have to do a little research and see what size speakers your vehicle has.
Tweeters and door speakers come in many sizes.
Aftermarket speakers can be used on a radio, but if you want them to be louder then you will want an amp which will need more work done.
Aftermarket radios tend to have a better internal amplifier then stock so it will genuinely sound good with new speakers.
Sent from my Z970 using Tapatalk
Everything RayGen12 said/typed. And I learned years ago putting a great speaker on a mediocre source signal can sound pretty amazing! And with an even higher quality signal from a really good head unit, WOW!
I'm all in favor of great speakers, and bought come $640 a pair PHD 5.1 Pro AF 5.25" drivers with separate tweeters, and WOW! PHD - Speakers - Model AF 5.1 KIT PRO -
John Kuthe...
John Kuthe...
No you dont need an amp to run aftermarket speaker but they will sound much much better with an amp. If your looking for cheap sound quality then pick up a headunit with a good eq on it and buy a small sub to free the speakers from playing bass. You can make a stock system sound much better. If you are planning To get aftermarket speakers i would reccomeded getting an amp for them.
raygen12
raygen12
Sioux Falls, SD
BSchrowang
