mirracomitch
my door speakers get distorted when i turn them up pretty loud. i only have 50 watts going to each door speaker. can someone help?
not enough info.my door speakers get distorted when i turn them up pretty loud. i only have 50 watts going to each door speaker. can someone help?
correct answertoo much power, or you may be pushing the amp too hard...what are the speakers and what amp?
based off the only info I hadmy bet is a HU.
COMMON HU outputlol....50x4:laugh:
that's a start for troubleshootinghaha nah dude i dont think that is the problem lol
i have a rockford fosgate p400-4 amp and my speakers are rockford fosgates also and im not sure what they are rated any more help guys thanks
more good infoi have an alpine iva-w200 hu
my current settings are:
bass+3
treble+2
bass frequency 80hz
treble frequency 17.5khz
ah HA. high pass isn't set properlyok i found out they only distort when there is bass playing so like if there is a section on a song with no bass then they dont distort. as soon as the bass comes on again they distort any help?
NOT NECESSARILY SOWell everyone is going to make fun of you, so I am going to actually try and help you with this issue, because not everyone is a self-proclaimed car audio genius. All the other people on the board that like to make fun of everyone else and act like jagoffs knew nothing until they got to this site, now that they have read a lot of "bona fide" information posted by people they don't even know, they consider themselves experts and make fun of anyone who asks a question that seems noobish...Anywho....
corrected.First thing, I would check the High Pass Filter on your amplifier, make sure it is in the "HP" setting, then, while listening to the music that makes them distort the worst, gradually adjust the crossover higher until the distortion stops. If you have bass boost on the HU or amp, turn it to 0.
good wordsMany will tell you that you really shouldn't use the HU to "boost" the signal of any frequencies. Only to make "cuts" i.e., turn down certain frequencies. If you don't have enough bass, add a speaker designed to produce bass--a good subwoofer. Maybe you already have one, we don't know, but don't rely on door speakers to provide you with any real bass below 80hz for average speakers...If you do have a sub and still feel the need to crank the bass up to +3, maybe you need another sub. Keep the low bass out of your door speaks, and let the subs handle it, that is what they are made for.
learning in progresswow thanks a lot man very helpful
i have 2 12" fosgate subs btw
so my crossover setting on my amp for my speakers should be somewhere around 90 hz am i correct?
finally we get a full set up! If the HU has HP on the outputs that would help too, there might be adjustable slopes also. I would use the steepest slope possible on the front speakers.ok yeah thanks guys im going to wait until the morning to change some settings.
my complete setup:
HU: alpine iva-w200
amp: rockford fosgate p400-4
speakers: rockford fosgate punch not sure which exact model
subs: rockford fosgate 12" p3s 2ohm
sealed enclosure
i have one mid and 1 tweeter in each door
and i have one tweeter in each pillar by my windshield
i think i will be able to fix it after dftnz7's advice
thanks to all!
