Speakers cut out.
morgans432
PLEASE HELP
I need help with this my speakers play fine and then they cut out. It just started and it plays then all of sudden it will shut off and then come back in. the subs still are playing but the speakers don't put anything out. I'm wondering if anyone has a solution to this problem.
check to make sure that you're wires are connected properly, (nothing showing where they connect to the head deck). Make sure the head deck is grounded OK. and than check to make sure that there is no cuts in the speaker cable, because if this touched a metal surface it would cause it to stop momentarily.
Good luck!
speakers work at low volume then once the bass kicks in it will go out and play really faint then come back on. I'm lost and kind of want to listen to music haha. Please help want to get this done.
also i hear like scratching noise or something like that. sounds like little clicks then stops and comes back. Sounds like it might be clipping but not sure.. PLEASE HELP
Is the amp going into protect? Is the sub amp drawing too much power? Watch the amp while playing music. When it cuts out, does the light go out? Does the protect light come on?
morgans432
morgans432
new jersey
morgans432
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
