Alright a couple months back i blew my 1 10" Kicker CVT, im finally about to replace the sub this week.
A CVT is gonna run me $70, I already have a box and a ZX400.1 to power it.
1 10" Kicker CVT (400 W rms) + Kicker ZX400.1 (400 w rms, monoblock)
so now im back at square one, and my system is in the original state of when i bought it.
now i wanna upgrade a little, first option.
do I add four new speakers, 2 4" KS400 coaxial speakers up front and 2 3.5" ks350 speakers in the back (Run me $70)
or do i add 2 4" CDT Audio classic 2 way component speakers (run me $100)
or do i instead go with 2 4" Diamond Audio CM3 Components (run me $130)
and what amp should i use to power them, should I use a 2 channel or a 4 channel? keep in mind I already have the monoblock 400 watt amp (also what wires will i need to wire up a second amp)
for the ks350 and ks400 speakers im looking at the kicker kx200.2 amp, would that be able to power all four speakers? some people have told me I should go without the 3.5" in the back alltogether but all my interior speakers are busted and i can replace them all for $70, or should I spend $100 on components and leave the rears as they are?
in any case if the kx200.2 amp isn't the best option, what can u guys recommend under $70 with shipping that could power either the 4 kicker coaxials or 2 CDT/Diamond components?
here are the stats on the speakers i am considering getting
KICKER KS400
# 2-way 4" speakers (pair)
# Polypropylene woofer cone with Santoprene surround
# 1/2" Kaladex dome tweeter
# Power range: 6-30 watts RMS (60 watts peak power)
# Frequency response: 60-20,000 Hz
# Sensitivity: 88 dB
# Top-mount depth: 1-7/8"
# Minor Cosmetic Blemishes
# 90-Day Manufacturer's Warranty
# Authorized Kicker Internet Dealer
Kicker KS350
# 2-way 3-1/2" speakers (pair)
# Power range: 6-20 watts RMS (40 watts peak power)
# Frequency response: 80-20,000 Hz
# Top-mount depth: 1-5/8"
CDT Audio Classic 4" 2-way componentss:
* 2-way 4" Component set
* Woofer: 4" Stamped Frame
* Power handling 70 Watts Rms
* 100Hz high pass
* Frequency response:70-20kHz.
* Impedance 4 Ohm
* Sensitivity: 91.1 dB.
* X-over:12 dB. SatNet-400
* Surround: Buytal rubber.
* Tweeter: 3/4" TW-19 Silk twtr.
* Suspension: Flat
* Cone: Carbon treated paper co
Diamond Audio 4" CM3 Series Components
* Drivers: Tweeter, Midbass
* Drivers per Channel: 2
* Power Range (watts): 20/60
* Impedance (ohms): 4
* Sensitivity with w/2.83-V input @ 1 meter (dB SPL): 90
* Freq,. Response 80Hz to 20kHz (3dB)
* Woofer Cone Material: Co-Polymer
* Tweeter Cone Material: Aluminum
Dimensions
* Mounting Type: Flush, Angle
* Mount Depth Largest Driver: 1.81"
* Diameter Largest Driver: 4"
and the amp i am considering is
Brand: Kicker
Condition: Factory Refurbished
RMS Power Output: 70W x 2 @ 4 Ohm
Peak Power Output: 140W x 2 @ 4 Ohm
Birdged Output: 200W x 1 @ 4 Ohm
Signal To Noise Ratio: 95dB
Frequency Response: 20-20,000Hz
Bass Boost: 18dB
Built-In Crossovers: HP- LP
THD @ 4 Ohm RMS Power: 1%
Ohm Load Stability: 2 Ohm
Low Level Input: Yes
Built in Cooling Fan: Yes
Bass Control Knob: No
does that amp match any of the speakers i want, if not what amp under $70 (really more like $50) will DO THE JOB, to just power my speakers... also have the option of running some speakers off my HU it is an alpine ida-x100 not sure of what kind of power the internal amp uses, some1 please help me im trying to buy this stuff tomorrow so i can have it in the car early next month
KICKER KS400
Kicker KS350
* 100Hz high pass
* Impedance 4 Ohm
* Suspension: Flat
Dimensions
Brand: Kicker
Bass Boost: 18dB
