Speaker wire?
jgonino
I need some speaker wire for my setup.
I have an alpine pdx4.150 powering my front components, and tweeters on seperate channels. I also have a fusion 2500d powering my single FI Q sub.
I have about 40 ft of 12guage KNU wire, but I dont think It can handle the power?
What should I get? I would refer twisted pair.
I always run thicker wires than needed, but have you ever really looked at the little tinsel wires you are running it in to ?
The tinsel wires are small but they are only a couple inches long. You could probably run a 4kw amp off 8 gauge if it's only an inch long. Same thing with fuses.
cheap radio shack 16 and 18 gauge wire FTW!!
i have 16 gauge on my mids (on 200 watts rms each) and sub (620 watts rms). and i have 18 gauge going to my tweeters (100 watts rms each).
I think wiring size is mostly a personal choice above a certain point. I use whatever I can find, I am one of the "wire is wire" types. Sometimes the higher priced stuff is more flexible though.
Curious question though, why would you use twisted pair for speaker wires ?
Choosing wiring size should be very to-the-point. Use what will handle the power, or larger. Simple as that.
i use metal clothes hangers. i disassemble them and straighten them out. then i tape them together to form a long line. then i bend them into shape to run from my trunk to my doors. they work great and never have to worry about broken wires.
jgonino
jgonino
Kansas City, MO
thugpassion
vegang
vegang
