Speaker wire questions. Size
cchheett
View attachment 26537172View attachment 26537172I am new to all this stuff and hope you guys can help me with a couple questions. I have 2 subwoofers that I will be using. They are Sundown Audio E-series 12". They are both 4 ohm each. I am going to hook them to a 1 ohm load to my mono amp "1200 watts rms" I will be using both voice coils. Will be 12 gauge wire going to be ok, or should I use 10 gauge.
I will need to put 2 wires together into the voice coil so it will go to the other coil etc. Is it going to be ok to do that. I just have never needed to use a voice coil with more then one wire. Will most voice coils handle 2 big wires to the coil. I hope this makes sense. Thanks for your time.
Just adding a picture of wiring I plan on using.
Thanks for the info. Should i buy fancy looking stuff for a car audio place. Or will be it ok, If i buy it from a hardware store. Thanks.
Thanks guys. Not sure if its ok to buy speaker wire from a hardware, or if i should buy the fancy stuff in the car shop. Thanks
The more costly stuff is going to be of a higher strand count and a lot more flexible so I would go with decent car audio wire.
cchheett
cchheett
Oregon
alec14
