Speaker to PC
  • 4
Rincux2
Latvia
Hi everyone.
I need some help connecting speaker to my PC.
The problem is, that the speaker is using 2 pin din connector and I can't connect that to my PC. I need some help converting it to normal PC audio connector.
I got:
Speaker
2-pin Din connector
2 normal PC audio connectors
As I see, speaker have 2 channels.
1st wire- Connected to bass speaker and little speaker
2nd wire- Connected only to bass speaker
I've tried:
Wrapping wires around connector and plugged in PC- Didn't work
Putting "naked" wires in audio port- Didn't work
Wrapping 1st wire to green connector and 2nd wire to red connector (Around metal thing not wire) and plugging in PC- Didn't work too
I tried different settings in Realtek HD Audio Manager (Starting from Line-in to Side Speaker Out)
Sorry for my bad at English, I'm Latvian.
Some pictures in attachment.
P.S I don't know which is right section for this
The PC doesn't make enough power to realistically drive speakers... it does make enough for say small computer speakers but not one of that size. Even most small speakers come with an extra USB connection to take more power with small built in amps.
Hmm... Will my speaker work if I connect it with this? (Pic in attachment)
I've never tried to make a home made computer speaker so I can't really tell you nor want to **** up your sound card.... best bet is to buy a 5 dollar set of computer speakers or a really cheap receiver...
403
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
402
538
457
Rincux2
Rincux2
Latvia
Rincux2
    May 31, 2024
    May 24, 2024
