Speaker connections
bushi
florida
Received my CDT's last night...cool!. There's one connection terminal on the speakers that is slimmer than the other (one fat, one skinny). Since they're not marked + or -, I assume the size difference of the terminals is the key.
Which size terminal is the positive?
Thanks
It's not going to hurt anything either way. But if you want to get the phase right use a 9 volt battery. Connect a wire to each terminal and connect them to the 9 volt. When you have it so the cone pushes out your set. Mark the terminals according to which side of the 9 volt they are connected to. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Positive is marked with a red dot on the cdt's turn the speaker upside down and look you should see it by the terminal !
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
228
325
294
Nobody is bashing anything. Just because I can use stainless, doesn't I should. The bananas I use are 4mm BFA style gold plated copper, pretty...
32
bushi
bushi
florida
Spddracer
    May 12, 2024
Brendon Jenness
    May 11, 2024
