soundstream xxx 10k fs/ft
joshy629
sound stream xxx10000d
the amp works perfectly. 10/10 mechanically. just has allot of scratches and wear on the outside of it from the previous owner. works fine. scratched don't effect how it works keep that in mind. the amp has 2/0 power and ground. i fit 2 0gauge into each. also it has 4 gauge speaker outs.
looking to sell to get a couple smaller amps so i can run each sub at .5 instead of both for a total of one ohm on this amp.
trades are for other amps only.
amp is a mono channel
4 ohms: 5500 watts x 1 channel
2 ohms: 7500 watts x 1 channel
1 ohm: 10,000 watts x 1 channel
Dimensions: 27" x 11.5" x 2.75
845 shipped
sorry about not a good pic forgot i needed username when i took the pic when it was daylight. but its the cpu sitting on the amp as you can see in the lower corner. the next pic is better
BEAST!!!
dang shame this is not a 6500... good luck with your sale and nice price //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
joshy629
joshy629
lawrenceburg ky
joshy629
audiobaun
    May 19, 2024
    May 19, 2024
