sound stream xxx10000d
the amp works perfectly. 10/10 mechanically. just has allot of scratches and wear on the outside of it from the previous owner. works fine. scratched don't effect how it works keep that in mind. the amp has 2/0 power and ground. i fit 2 0gauge into each. also it has 4 gauge speaker outs.
looking to sell to get a couple smaller amps so i can run each sub at .5 instead of both for a total of one ohm on this amp.
trades are for other amps only.
amp is a mono channel
4 ohms: 5500 watts x 1 channel
2 ohms: 7500 watts x 1 channel
1 ohm: 10,000 watts x 1 channel
Dimensions: 27" x 11.5" x 2.75
845 shipped
sorry about not a good pic forgot i needed username when i took the pic when it was daylight. but its the cpu sitting on the amp as you can see in the lower corner. the next pic is better
BEAST!!!
845 shipped
BEAST!!!
