Soundstream TRX 4.640 4 Channel BEAST CHEAP
jdubbau
Rating: 66.7%
4 2 0
Item(s) for Sale: Soundstream TRX 4.640
10/10 Functionality and 6.5,7/10 or so on cosmetic as it does have some damage to the fins as there is a bend in one and paint rubbed off as this is how I got it. Otherwise great amp that actually surprised me on the output. Uses 3 25amp fuses as well and I also noticed the endcaps did not come with this amp and never noticed until now.
  • 100 Watt x 4 Channel @ 4 Ohm
  • 160 Watt x 4 Channel @ 2 Ohm
  • 320 Watt x 2 Channel @ 1 Ohm
  • 640 Watt MAX
  • Class A/B
  • 4/3/2 Channel Operation
  • MOSFET Pulse Width Modulated Power Supply
  • IDI (Intelligent Distress Indicator)
  • LED Power, Protect
  • Gloss Black Finish w/ Gray End Caps
  • Three-Way Protection Circuitry (thermal, short, impedance)
  • Variable Crossovers (HPF/Full/LPF)
  • Variable Low/High pass filter (50-150 Hz)
  • Variable Bass Boost
  • Pre-Amp Outputs
  • Platinum RCA Level Inputs
  • Platinum 4 Gauge Power Connectors
  • Frequency Response: 10-3.5 kHz
  • Phase Shift: 0-180°
  • Direct 4 ga. Power & 8 ga. Speaker Terminals
  • Dimensions: 20"L x 11"W x 2-5/8"H
Price: $115 Shipped in Con US only
A few BETTER pics of amp working or powered on as well as the negative issues with the case or top plate that is missing the end caps that I was originally unaware of.
$90 Shipped in Con US
jdubbau
jdubbau
evansville In
mikelaubach
