soundstream stealth series stl6.620
  • 4
nate56
colorado
1. Product:
2. Specs:
Stealth Series 6-Channel Class AB Car Amplifier
RMS Power Rating:
4 ohms: 60 watts x 4 chan. + 100 watts x 2 chan.
2 ohms: 80 watts x 4 chan. + 150 watts x 2 chan.
Bridged, 4 ohms: 160 watts x 2 chan.
Bridged, 4 ohms: 300 watts x 1 chan.
Pulse Width Modulated MOSFET power supply
Stackable chassis for multiple amplifiers
Delayed on/off circuit
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Three-way circuitry protects against overheating, speaker shortages, and overload
8 Gauge speaker terminal inputs
Detent crossover and gain adjustments
Thru-Pass outputs
Black finish with chrome accents
LED power (green) and protect (red) indicators
6/5/4 Channel operation
Speaker-level inputs
Nickel-plated RCA level inputs
Nickel-plated screw terminals
Input sensitivity: .2-5V
Variable high-pass filter:
Channels 1 to 2: 20-5,000 Hz
Channels 3 to 6: 20-500 Hz
Variable low-pass filter:
Channels 3 to 5: 200-5,000 Hz
Channel 6: 50-500 Hz
Subsonic filter: 20-5,000 Hz
Signal-to-noise ratio: 89dB
THD (Total Harmonic Distortion): 0.03%
Damping factor: >200
Frequency response: 15-25,000 Hz
Stereo separation: 46dB
Dimensions: 11.25"L x 6.5"W x 4.5"H
4 Gauge power wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
3. Description/Condition:
8-9 looks couple of nicks only like a month old
10/10 working
4. Price: :
150 +shipping OBO
TRADES ACCEPTED
5. Pictures:
http://s1032.photobucket.com/user/rundle56/library/?sort=3&page=1
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Hello I have the soundstream bx 108z and just recently the remote wier came out of the power connector so I put it back in and then noticed that...
nate56
nate56
colorado
nate56
    May 31, 2024
    May 24, 2024
