Soundstream RUB1.1600D MONOBLOCK (LIGHTLY USED)= $175 SHIPPED
Soundstream RUB4.500 4CHANNEL (MOUNTED BUT NEVER INSTALLED OR USED)=$ 125 SHIPPED
I HAVE THE ORIGINAL BOXES FOR BOTH AMPS ASWELL AS BOOKLETS AND INCLUDED ACCESORIES
PRICES ARE OBO.
Detailed Description of the RUB1.1600D:
Soundstream RUB1.1600D 1600 Watts RMS Mono Block Rubicon Series Subwoofer Amplifier Model No. RUB1.1600D Part No. RUB1.1600D
RMS Power Range : 1100-1600 Watts
Number Of Channels: 1
Low Frequency response: 15 Hz
High Frequency Response: 150 Hz
Built In Crossovers: Yes
Channel Separation: YEs
Features:
Power output:
1100 Watts RMS x 1 @ 2 ohms
1600 Watts RMS x 1 @ 1 ohms
Midnight blue finish w/ brushed accents
Regulated MOSFET puls width modulated power supply
Three-way protection circuitry (thermal, short, impedance)
Twin stack technology (strap amps together for double power)
Delayed on/off circuit
Variable crossovers
Variable bass boost
Variable subsonic filter
180 degree phase control
Signal-to-noise ratio: 105dB
Damping factor: >300
Signal voltage: 200mV-6V
Harmonic distortion: 0.50%
Direct wire 4ga. power, 8ga speaker terminals
Dimensions: H: 2" x W: 8" x L: 15.75"
Detailed Description of the RUB4.500:
Soundstream RUB4.500 500 Watts RMS 4-Channel Rubicon Series A/B Class Amplifier Model No. RUB4500 Part No. RUB4.500
RMS Power Range : 4x125 Watts
Number Of Channels: 4
Low Frequency response: 10 Hz
High Frequency Response: 35000 Hz
Channel Separation: Yes
Features:
Power output:
RMS Power @ 4 ohms: 75 watts x 4
RMS Power @ 2 ohms: 125 watts x 4
RMS Power @ 4 ohms bridged: 250 watts x 2
THD 0.015%
Damping factor: >250
Signal sensitivity: 0.2V-6V
50Hz Bass Boost: 6 or 12dB
35Hz Subsonic Filter
Infinitely variable crossovers w/ multipliers (High/Full/Band/Low)
Mosfet PWM power supply
IDI intelligent distress indicator for thermal, short, & impedance protection
Turn on/off delay
Tri-mode capable
2-ohm stereo / 4-ohm mono stable
High & low level input
Platinum 4 AWG power block
Dimensions: 8"(W) x 2"(H) x 13.75"(L)
WILL BE SHIPPED VIA UPS.
RUB 4.500
RUB 1.1600
PRICES ARE OBO.
Features:
Power output:
Variable crossovers
Variable bass boost
Features:
Power output:
THD 0.015%
Turn on/off delay
Tri-mode capable
RUB 4.500
RUB 1.1600
