Soundqubed q1-3500d.1
EXTREMECHEVYMAN
SOUNDQUBED Q1-3500D.1
Amp is in great shape. used very little on good electrical. now it is boxed up in original box with manual, remote knob, everything it came with from SQ. Amp was purchased ON oct 2013. an only used maybe 1-2 hrs.
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2V ~ 5V
Variable Low Pass Filter 20Hz ~ 200Hz @ 24dB/Slope
Subsonic Filter 10Hz ~ 50Hz @ 24dB/Slope
2 amp linkable connection Output Master / Input Slave
Clipping Display Led On Remote Gain Control
Signal to Noise Ratio 85dB
Damping Factor 250
Efficiency 85% at 4 ohm
External Fuse Rating 380 Amp in-line, 760 for pair
Tested Voltage 14.4V
Working Voltage 9.5V ~ 18.5V**
4 ohm power @ 12V @ 1% THD 750W x 1
4 ohm power @ 14.4V @ 1% THD 1400W x 1
2 ohm power @ 14.4V @ 1% THD 2600W x 1
1 ohm power @ 14.4V @
1 ohm Power @ 16V** @ 1% THD 5300W x 1
1 ohm Power @ 18V** @ 1% THD 6000W x 1
1 ohm Power @ 18V** @ 10% THD 7500W x 1
2 ohm Linked Power @ 14.4V @ 1% THD 8600W x 1
2 ohm Linked Power @ 16V** @ 1% THD 10600W x 1
2 ohm Linked Power @ 18V** @ 1% THD 12000W x 1
2 ohm Linked Power @ 18V** @ 10% THD 15000W x 1
Dimensions (mm) 657.2mm (L) x 241.3mm (W) x 66.7mm (H)
Dimensions (in) 25.875in (L) x 9.5in (W) x 2.625in (H)
Power and Ground Inputs 0 Gauge x 2
575.00+S&H IN CONUS
WILL BE SHIPED UPS WITH INSURANCE AN TRACKING
freedback
extremechevyman67
EXTREMECHEVYMAN
EXTREMECHEVYMAN
Washburn, Tennessee, United States
EXTREMECHEVYMAN
vegang
vegang
