Of course, the higher the point in winding the larger voltage drop.I'm curious to test out how the voltage across the terminals of a battery charger will change with the current draw of the batteries to the amp. I guess it depends on the voltage regulation that the charger allows on the secondary winding of the transformer.
please explain .....thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif您好喬治!中國!
Yes, but the voltage isn't alternating. The voltage basically has a zero slope and is a flat line that is acting like a step function that can either increase or decrease, but keeps the same flat shape. RMS is used for periodic waveforms, such as sine, sawtooth, and square waves.Because the output is pulsating before you connect to a battery.
there are no letters or anything to translate sir..Translate that, mister.
No, RMS voltage can be aplied if a quantity varies above zero.Yes, but the voltage isn't alternating. The voltage basically has a zero slope and is a flat line that is acting like a step function that can either increase or decrease, but keeps the same flat shape. RMS is used for periodic waveforms, such as sine, sawtooth, and square waves.
Exactly, they are using it for an AC signal.No, RMS voltage can be aplied if a quantity varies above zero.
you can use a simple on line app and put a dc offset to try it by yourself
http://phy.hk/wiki/englishhtm/Rms.htm
Yes the people pull 13kW out of the SD8000 using those terminals.But, anyways. One thing that concerns me with the larger amps, like the 5000 and 8000 watt amps is that there's only 1 set of power and ground terminals. Are people expected to safely pull that much current through a single 1/0 wire?
