soundigital SD16K
is the amp shooting blanks? //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
It just won't output sound - only static. I think it was damaged in shipping.
that would be Juicy. good luck finding someone to fix the Crown.
Crown International in IN does
Ive heard of quite a few people blowing these Crowns tho
Team DOA has smoked theirs 1 or 2 times //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Yes it is possible if you run voltage too high. They will NOT do 16v and they do not like .7ohms and below, thats why they put out at 4 ohms
You can blow any amp.
Run it right and the quality amps will not blow up and will put out like it should. Use cheaper korean amps and watch them pop just turning on.......oh and having to feed 17+v and dropping to .5 ohms and below
For you ? 2 million dollars //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
How much for me? C'mon man, we go way back...//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
pm sent.
Daily setup. not 16volts. running it at 4 ohm.
if you had it fixed a few times and you didnt send it to Crown thats probably why you kept blowing it. PM sent back.
never sent it to Crown. just some local guy as on Jbl website said they wouldn't fix it. my friend had it working for a day then poof. i will give him the number so he can call.
GTFO feggot....your not going to buy that amp...you just want attention....and bullshit on you run this and that on your midbass....your a lying feggot troll...and to correct you i'm running 1500...my amp is capable of 3800 though;)
check it out CRACKY...its bought as of this morning....you can PM MURILO yourself punk....
im gonna do a break in period on this amp to where i keep the gains down and let it play for while.
most amps will blow if they dont have speakers hooked up to complete the circuit when powered up, the amp will read a short and the power will build up and have no where to discharge it. (at least my theory based on the electronics class i took in prison). could be wrong tho but i'm not taking that chance.
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
sub-FATHER
Resurecting this sport
sub-FATHER
denver, CO.
TnT_Sounds
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
