Sound deadning
Just curious how big of an impact does sound deadning have in spl? Will it be noticeably louder or does is just make the sound cleaner?
Sent from my 5054N using Tapatalk
You hit the low notes better because deadening reduces cabin peak frequency. Reduced flex gives an spl boost as well. No rattles helps cleaner sound as well.
If you are currently flexing like a maniac, you'll want to brace instead of just CLD tiles and that should get you a great bit louder.
I did two layers of deadener on the roof and it still wobbled and started ripping. I put plywood on the roof and now its solid AF. Gained a good bit of spl and low end impact from doing so.
I was thinking the sound mat (or what ever Sound Qubed calls their deadner) throughout the truck and I was gonna fiberglass the headliner
SQ's is nice for the price.. Use dead now or get ready to rip everything out after a few days after install so you can do it right and use dead as much as possible.. The rattling will be louder then your system. That's no BS.
Waiting for tax returns still so I can order new door panels and get the deadner. Is doing the roof and floor worth it?
Yes every flat panel u can reach is worth covering or putting some on.... Top, bottom, sides everywhere... NO BS makes a massive difference...
I deadened my doors today after getting a new pair of comps. Tried them before and after deadening ... before they sounded decent ... with the deadening: I had to pull all the junk out of the storage pockets becauze they were rattling!
Got the deadener in; Ensolite will be next (need another warm day).
dev199505
dev199505
US
T Reds 19
