Sound Deadener???
i wasn't trying to offend you. Sorry if i did. Let it be know. You are still the man
Damplifier and Damplifier Pro do not need to cover every inch either. Maybe try and understand how sound deadening mats work before you decide on purchasing anything.
Nobody wants to lose the rights to their own names now. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif (cough Kleenex) Companies hate that. Well Ant doesn't for that reason, but they do have names for their products. :p
Covering every inch seemed to just be marketing from deadening companies. Search "ultimate sound deadening" here and you'll see an install that covers every inch with layers upon layers of silliness. If that install was done by an employee of a deadening company, people might probably think that's how you're supposed to do it.
Before SDS, there was no talk about the 25% coverage strategy/technique, which I'm sure certain deadening companies aren't happy about that technique catching on.
//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
Look at the popular automotive shows like Overhaulin'; Chop, Cut, Rebuild; Street Customs; Pimp My Ride; and Unique Whips. What do most of these shows do when showing the sound deadening process? Well, they tend to cover every square friggin inch of sheet metal.
Unique Whips took it even further by covering right over a rusty floorboard. I guess that was needed to stop the rust from resonating.//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Anyhow, why do these shows promote full sheet metal coverage? To sell more product!//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif:greedy://content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif:greedy://content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
One of the most important things to understand is that more coverage with an inferior product is not better than less coverage with a higher quality material. In other words, don't be lured into using an inferior product like FatMat just because you get more coverage. All you'll end up accomplishing is spending more time laying down more material and ultimately achieving worse results.
Usually, but not always.
Also, just because all your friends in the neigborhood eat chips and salsa, doesn't mean it's the only good dip out there. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Point is: there's more to "deadener" than CLD mat.
Structural damping, whether extensionalor constrained-layer, provides an
at-the-source solution to noise control
problems. Further, it is not always necessary
to use 100 percent panel coverage
to achieve significant noise reductions.
For example, 50 percent coverage
will provide a noise reduction that is typically only 3 decibels (dB) less than
for 100 percent coverage; 25 percent
coverage is only 6 dB less. When properly
used, damping can be as cost effective
as it is acoustically effective.
http://www.earsc.com/pdfs/engineering/understandingdamping.pdf
Also, FatMat is not "deadener." Would you put CLD mat on your roof?
Sorry, don't buy it. The fact that they are describing vibration damping in terms of dBs of noise reduction tells you they are measuring something else. The fact that they aren't specifying frequencies makes you wonder if they measured anything at all. That site usually has pretty good information, but this seems like something from the marketing department. A 6 dB noise reduction would be worth having. If you could get it with extra vibration damper I'd be all over it.
Ok, what are they measuring, then? 100% of anyone buying CLD mat here wants a noise reduction of some sort via damping. Find me someone that doesn't.
What'cu talkin' bout. Figures 5 and 6 are loss factors at 1k as per layer thickness taking temp into account. May have motivations to sell damping stuff, but you cannot deny the bruit point they're making here.
25% is a good starting point. Could take more, but I doubt less. Good points in this thread overall, but let's not got dogmatic.
I'm not being dogmatic - there are applications where going past 25% yields a useful benefit. 25% is just a guide. I repeat however, there is nothing in the PDF you linked that substantiates the relationhsip stated between coverage percentage and result. Almost everything in that PDF is taken directly from:
Vibration Damping
By Ahid D. Nashif, David I. G. Jones, John Phillips Henderson
including the illustrations and charts. Everything except the percentage coverage assertions. The ideal is going to be between 25% and 50% with 25% being the safe sweet spot when everything is considered. How can 100% coverage ever be useful when areas of the panel are never in motion? It's a marketing line thrown into accepted science.
djarmy2004
djarmy2004
djarmy2004
Hopkinsville, KY
FoxPro5
BP1Fanatic
BP1Fanatic
