Sooo......Active=FTW
Thats where I was getting confused^^^ Not having the sub in led me to interpret the crossover on the deck waaayyy wrong.
Im low-passing the sub at 63hz, 24db. Then the ssf will control the bottom end, but its set too high.
BTW thanks a lot for the help Ramos...(and James Bang)
Time to go for a cruise and enjoy the part Ive been missing. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
edit- I knew something sounded weird with the tweets
After a little cruise:
Low-L 0 63hz
Low-R 0 63hz
Mid-L-L -1 50hz
Mid-L-R 0 50hz
Mid-H-L -1 3.2khz
Mid-H-R 0 3.2khz
High-L -4 2.5khz
High-R -2 2.5khz
The mids havent changed a bit. Adjusting the tweets has been my problem. Finally gettin there now though lol.
My question here is:
If the component set you buy comes with passive crossovers, wouldn't the people that make the component set, set the crossover points that best suit the component set? Or it more of a personal preference thing, where most people have tastes different than the creators of the component set?
9 times out of 10 the passive crossover points are a "safe" crossover point. Meaning with the realtively low slopes of the passives ( usually 6db-12db ) your components are going to be safe from idiot consumer abuse. Doesn't mean they are the best or ideal. Just means they are a little safer for the everyday average joe blow. Going active with a passive set, using the passive crossover is a good starting point. But with an active setup, most of the time you have much steeper slopes to control things a little better //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well james, I have learned one thing from this thread...
you are a ****ing ***
^ lol
Heres where Im at now:
Low-L 0 63hz (12db/24db)
Mid-L-L -1 50hz/63hz (24db/12db)
Mid-L-R 0 50hz/63hz (24db/12db)
Mid-H-L -1 3.2khz 24db
Mid-H-R 0 3.2khz 24db
High-L -3 2.5khz/3.2khz (24db/12db)
High-R 0 2.5khz 24db
Struggling to find the sweet spot.....biggest thing is balancing out everything on the drivers side, mainly just the tweet.
i would start w/
sub 80hz -24db/oct
mid low 80hz -24db/oct
mid high 3.2khz -24db/oct
highs 3.2khz -24/db/oct
I recommend keeping both sides equal w/ xover points and slopes, but I attenuate when needed to have both sides balanced.
to get a balance, try playing the tweets only, then balance left and right to where they sound equally loud on either side. I do that by balancing far right and left and adjusting the levels on the crossover or gains, if you have independent gains.
then do the same for mids.
after that, you balance your mids and tweets (attenuating or boosting left and right together if any adjustment is needed) and repeat for your sub.
do all that after getting the phase right. http://www.zshare.net/audio/5006010928145cf2/
check phase w/ mids and tweets playing separately (turn mids off when checking tweets, and vice versa). it'll be easier.
i would start w/
sub 80hz -24db/oct
Thanks man, much appreciated, thats exactly the info I needed!
I don't understand what safety has to do with it, really. Sure, you can run a tweeter down way too low and push it to it's mechanical excursion limit fry it, but passives are designed by the manufacturer to make the sound transition the most optimal after testing them out. Some do it consistantly different than others...Dyn uses 6 db/Oct slopes and I've seen Rainbow use 18db/oct.
Also, steeper slopes aren't better or more ideal. It's just a different attenuation used for several different reasons. Not saying you said, that just saying in general.
A passive comp set in the hands of a veteran installer and tuner can and WILL sound better than someone installing speakers at BB. The car determines the end result, not the slopes. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
MikeyB
CarAudio.com Addict ®
MikeyB
H-Town, MI
stophatin
