sony xplode HU giving me problems HELP
there is 6 speakers in the front, and 4 in the rear. the wires going to head unit it splits then in to 4 like front R, front L, rear R, rear L so i would have to take off door panels to do so. so some where the speakers connect for there to be 4 channels. also i noticed if i program the head unit to have no EQ sound won't cut out AS much. though when i but the window down for use turn single pretty much use any thing that uses electricity the sound cuts out. not sure if that helps narrow any thing down. if a amp will help I'm able to hook it up i have access to a few lower end amp if that would fix the problem.
If you hook it up to an amp it might fix your problem. If you hook too many speakers to an amp for example it may play at low volume but when you turn it up it will cut out. So I've seen something similar happen.
There is almost no way someone one here is going to be able to give you the exact problem to fix. Insulate the extra wires you have hanging out behind the radio leave the radio out and take it to someone who actually knows what he is doing.
ju5nic
ju5nic
PA
CrossoverOre
AJ (ACE)
    Jun 28, 2026
