Sony Xplod XM-2150GSX Amplfier 760 watts
  • 1
Dooka4u4
PA
I have a sony amplifier that is a 2 channel amplifer. its the Xplod XM-2150GSX model. I currently have 2 subs that i want to run it off of. Do i need to wire them in parallel and bridge them. I think the amplifer is a 2 channel amp.
so like i would wire the positives of the two subs to the one positive on the right channel and then wire the negatives to the negative of the left channel for bridging...
thanks,
jim
931
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
Dooka4u4
Dooka4u4
PA
Dooka4u4
