Sony xplod enclosure HELP
maynap
Hello everyone ,
I would like to build a ported enclosure for my subwoofer so it can produce better lows , it's actually mounted in a sealed box , it does hit hard but below 35hz it's hard to hear , knowing that the sub frequencey response is 18 hz - 2000 hz
My sub model is xs L121p5 , 12"
It would be great if someone could help me with calculations and measurments
Thank you very much
Hello everyone ,
Thank you very much
well man everyone here will tell u building your own box is best., that said for a 350 watt sony sub i found 1 thattll work for that sub on walmart site for $38 but i doubt u would be able to order it lol.. (i searched pics of your country very pretty cities) that sub doesn't need a big box and port size is mostly determined by box size but we also need to know what amp u are running to it the actual rms power sub is getting to check for port noise..
Hello,
Thank you for you reply , and yeah we have nice cities and weather here you should visit
Actually I can't buy a box so I need to build one and would like that it will be tuned to somewhere at 30hz , I have a little amp MTX Audio TC2002 that pushes 200w RMS at 4ohm in bridged mode so it's not the best amp for that sub , but any suggestions to the best amp for that sub ? something not expensive
Thank you
Hello,
Thank you
there are alot of amps u being able to get them is the problem.. if u can find a jbl 500 and infinity 551 (they test at 650rms or so at 2ohm 350 or more at 4 ohm) maybe u could find 1 of those and later get a dual 4 ohm sub to get all the power from amp i'll look for 2 channels for u later.. ok box i came up with is sort of like the 1 i have my pioneer 3003 in 27" wide x14" high x 15" deep with 2"wide x 12.5" high slot port 28" long should tune to 35hz after your sub disp. and will play down below 30hz safely(now the depth if me figuring a double front baffle board, that will help u if u get heavier sub later) port air velocity is very low but like u said i hope u can get bigger amp.. or u can just copy my prefab box which did well on my pioneer box is just not as long with 1.5" wide port i can run that one for u too later which would be better for amp u have now..
I saw your 3003 videos and that thing hits really hard lol ,
can you make me a little measurement sheet for that box so I can convert to mellimeters and start building it ?, and also i think its good if I want to upgrade to a better sub later
I will also try to search for the amps that you listed or something similar because the choice here is very limited
I saw your 3003 videos and that thing hits really hard lol , can you make me a little measurement sheet for that box so I can convert to mellimeters and start building it ?, and also i think its good if I want to upgrade to a better sub later
man i'm not good at mocking up stuff to show i only use paper to get dimensions and put that in wins box program to check box freq curve and port air velocity.. i'll run 1 again later with 1.75"w port see what it shows., just remember if u go with amp like 4 times bigger u would need little more port area but if u can find nice 5-900 rms amp that would be good for the 1.5-1.75" w port as long as u stay around same box size.. i could draw up the box and take of pic of it and email it to u tonite, send me a private message with email, unless someone else mocks 1 up for u ..
Allright
I would like a box that will let me put bigger sub/amp without loosing the lower end frequencies so i guess like you said around 1.5 - 1.75" port will be great, correct me if i'm wrong
i've sent you a private message , and thank you very much for you help
I will put it i a BMW E34 trunk that has 460 liters
nvm, i thought you were putting an 18 in. i see that you're doing a 12, that will fit no problem. you need ~2 cubes net
is the sony xplod the only subwoofer you want to use? is anything else available
Yeah i'm planning to put it facing the trunk lid , or i have an idea where the sub and the vent is on the side of the box like some hometheater subs but it's not important ,
And i do have 20 inches of height and width , the trunk is pretty big
maynap
maynap
Sousse, Tunisia
maynap
