I know Xplod has a bad reputation but how are there amps?I'm thinking of buying one.
Yea when you buy this overrated crap you're can damage your equipment and your hearing from the distortion. Amps where the dollar per watt is so cheap it seems too good to be true (Sony) it generally is. In fact, their true power output can be more expensive than a reputable brand that underrates their equipment. Here is a passage from an article:Originally posted by grizzjwill NOOOOOOOO dont do it. There amps are overratted and are almost as bad as the subs. I have a friend with a 1200 watt sony amp and he hooked it up to 2 12" jl w3's and i have a mtx 8302 amp 425 watts and they sounded so much louder and better than from his amp and he paid about the smae for it as i did for mine so i really dotn suggest getting a sony amp.
For those of you who demand more of an explanation on why
ratings vary so much, the law does not require enough information
to be printed on the products rating. And what information the
law does require most people don't understand anyway. The first
of the two amplifiers was rated under NON-REAL conditions in a
test lab connected to a "dummy load" rather than a real speaker.
In the lab, under ideal conditions, the amplifier was tested to
have 50 watts. Then they found if they use a tone rather than
music the power doubled, easy to understand since the amp is
only playing one note instead of combinations of 20,000 notes.
Then they discovered that if they raise the voltage to 15 or 16
volts the power doubled again. Then they discovered that if you
let the amp sit with no signal going to it, and then burst it
with one note for a millisecond, the peak (MAX) measured higher
still! Now the power supply and most of the other parts in the
amplifier are getting so hot that the amp is starting to smell,
so they found out that if you spray freon on the amplifier and
keep it cold, the voltage could be increased to 19 volts before
smoke rolls out of it. So that's what they do, and however high
the power meter says just before the amp smokes is what they
print on the box. The second of the two amplifiers was rated
under simulated worst case conditions with low voltage (12 VDC)
across the entire musical spectrum with no distortion. A rating
that will be accurate for the life of the amplifier even if it is
never shut off. That's the difference.
You honestly think Sony is underrated???//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gifOriginally posted by LuNaTiC hey jayjay where the **** did you get that info. Thats the stupidest thing i'v heard for a long time. no one would overrate there amp that much. And anyways i'v heard the sony, i wouldn't buy it with out a test. if any thing its pushing over what it says.
Your ears told you if anything a Sony amp pushes more than what it says?if any thing its pushing over what it says.
