Sold Sony XM2000R
jtholley03
Like new Sony XM2000R for sale. $2300. Amp new was $6000. Selling to help fund business. Awesome amp
Specs from Sony:
300w x 2 at 4 ohms 20-20,000Hz 0.02% THD
600w x 2 at 2 ohms 20-20,000Hz 0.02% THD
1,000w x 1 at 4 ohms 20-20,000Hz 0.02% THD
Four independent final stages: left and right positive & negative: each with its own Pulse Width Modulation power supply
Cascade connection output stage uses eight transistors per channel cascaded to the final pair
Ultra-high speed MOS FET output devices
Seperate FET power supply for voltage stage
Drives reactive loads at rated power: phase angles from 60 degreess capacitive to 60 degrees inductive
Active thermal management
Twin 70A slow-trip circuit breakers
Variable Subsonic Filter 7-40 Hz
28-1.2"w x 4-1/2"h x x17-3/4"d
A true dual mono amp.
Email me with any questions.
jtholley03
jtholley03
Bristow, VA
jtholley03
michigan born
    May 14, 2026
michigan born
    May 14, 2026
