Sony Install
  • 2
JTuck
I am struggling to fit a Sony CD receiver that my brother donated from his old car, but without wiring instructions.
The wire connections are as follows.
From the unit via a black box with 6AMP fuse and electronics within
Yellow
Black
Direct from unit
Red with 1 AMP fuse
Black
I assume the yellow is permanent positive, red is to ignition and both
the blacks to earth, but any clarification would help
Thanks
729
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
932
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
JTuck
JTuck
England
phattcow
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
