Sony 1200 watt sub Question
Lime1
Can I take the + of 2 1200 watt sony speakers and the - and hook them up to a bridge on a 1200 2 channel sony XM-2200GTX amp? will this cause any damage. How would I hook them up to the amp to get the most out of the amp? I want my speakers to bang I have faith I know they can do it, Should I hook them up to 2 ohm will that help and how exactly do iI do that? Would it give me deep rich bass??? //content.invisioncic.com/y282845/emoticons/spank.gif.0d78e34d42ea8780359e903aeb6697d6.gif
no you cannot... the amp is not 2 ohm stable bridged.. you'll have to wire them in stereo... the amp does not push a lot of power... but it can still sound decent...
and believe it or not... everyone here will bash sony but i install them all the time... at ccity we sell infinity... mtx... polk... and sony subs a lot...
mostly infinity and sony... if i sold 20 infinity subs and 20 sony p5's... i guarantee that at least 5 infinity subs would come back in less than 3 months... it happens all the time... i had 3 come back today... not due to faulty install though.. but they just don't hold up... 2 were blown and 1 the tinsel lead was in half... i haven't seen a blown p5 yet that i can think of... and we put over 500 watts a piece to 2 10's in a car and it's never been back... they really do hold up good... flame me if you want though....
yes i know it does... but that's BY 2... AND that's max power... that's 2 subs at 2 ohms each... these are 4 ohm subs... so you have to look at what it says at... x 2 @ 4 ohms RMS... and here it is direct from sony's website...
1200W max power
200W x 2 RMS into 4 ohms, 20Hz - 20kHz @ 0.1% THD
500W x 1 RMS into 4 ohms, 20Hz - 20kHz @ 0.15% THD
Class A/B
Variable 50-300Hz low pass filter
40Hz EQ boost
Line level through-put
MOSFET output stage & power supply
RCA & speaker level inputs
and direct from ccity's webpage...
Power (Watts RMS into 4 ohms x Channels) 200 x 2
Power (Watts RMS into 2 ohms x Channels) 250 x 2
Bridged power x Channels (4 Ohms) 500 x 1
you will get 200w x 2 @ 4 ohms... that should power them.... not the best but it will power them... that's the ONLY way you should wire it
wire one sub per channel... + to + and - to -... and the same for the other side... do not bridge
Sony is horrible....lemme demonstrate
Sony=
Dont be a jew, buy a real sub..... take the padlock off your wallet and get something that will actually perform!
Lime1
Lime1
Jersey City, NJ
Norcalracer283
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
