Sonicelectronix Boxes Question.
korndawg
IA
I just put in a IDQ12 into a sealed 1.0 Sonic Electronix box, and due to some probs i'm having, i'm gonna start from scratch on the install. Without taking my box apart right now, I'm unsure what size of slide connectors i need to hook up to the binding posts. Its either .250 or .205. Anyone know what size they are? Or better yet, is there a better way to connect? I wanted to make an order for them today and I just wanna take my sub out once //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Most terminal cups, in my experience, use the .250" connectors.
There is always the option to solder the wires to the tabs, though you may want to remove the lugs from the plastic housing, and then reinstall them after you've finished your soldering.
Thanks. I was thinking the same thing. Gonna order me up a PXA-h100, all new wires and start from scratch again. I hate troubleshooting and tuning //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'm just curious... what kind of problems are you having exactly? It's pretty hard to mess up when dealing with a sealed box and 1 cubic foot for a 12" driver is probably the most common of them out there. So long as the sub's specs are somewhat near that, it should sound just fine. Have you looked into other settings maybe that may be off or at least less-than-optimal?
Are you not getting the type of sound you want or just not loud enough?
korndawg
korndawg
IA
lilboom
Mike Mccabe
