Son of a B*tch.....
Can you get a very small flat head screwdriver under the screw? A little pressure up from beneath it may get it started for you.
If it really isnt coming out, and you cant wedge it up like suggested, then take a drill bit that is just slightly smaller than the screw and eliminate it //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
Sell the amp and get away from Hifonics...
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif Awsome suggestion buddy, thanks for the contribution!
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif you should check the model number before you talk bad on the amp
Maybe you could use a lil flathead underneath and get it out?
Edit: Somone beat me to it:(
you mean just reverse it out with the drillbit?
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif you should check the model number before you talk bad on the ampMaybe you could use a lil flathead underneath and get it out?
whats that have have anything to do with it?
No, I mean drill through the screw turning it into little, tiny pieces of metal //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
or drill a tiny hole in the middle then sacrifice a mini flat tip , gently tap it into the hole then unscrew it
Ali1
e6300 FTW
Ali1
U.S.
saltyreefguy
