SOLO X 18 Amp setup under $400
I found 2 bamf 4000d was thinking of running I'n series at 4000+ rms but probably overrated by a 1000 but both new at $380 shipped.
you'll get about 2k rms maybe tops out of those amps. just save more and buy a better bigger amp. that will be your best bet. unless you want an AP3K
---------- Post added at 09:22 AM ---------- Previous post was at 09:22 AM ----------
btw wrong section ha ha
It will. I'll be running 2 of the largest deep cycle optimas cap 200+ alt all 0ga. I just need to know what amp is a good bet on the solo x so i can figure the amps my truck needs to hold Atleast 12volts.
well in order to get a good amount of power you'll need some bigger better batts then those optimas. also what kind of power are you trying to throw at it? or what do you want to throw at it?
yeah the aq is the best choice with your budget imo. but like sac said, id save up about double what you have now and get a higher quality amp. cool amps are happy amps //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Tony95bagged
Tony95bagged
Texas
xShoWTeKx
