Solid audio f2500d 10000w
Solid audio
Click on photo to see the guts of the amp
I have a really interesting solid audio f2500d. It's 10000w which I have never seen before. If interested make me an offer.
[/img]
It says 10000w on it and I've never seen one say that before. I've only seen the 2500w ones before. Also the inside has extra coils and 6 40a fuses . Also the the 2500 ones always ran high around 3k.
It does NOT do 10k rms. Or 10000 peak. Period. Never ever will it. If it's different on the inside the post a pic. Also follow the forum rules for selling don't act like a tard
If you click the picture you can see the inside of it. How do you know it doesn't do 10k?
this is a real 2500 watt amp and yours dont even compare. Real as in these amps are tested and survived the amp dyno rather than having stuff labeled onto the amp and some clueless guy thinking they actually do their rated power just because its labeled on there.
6 40 amp fuses is max possible current draw at failure so probably a heavy clip. 6 x 40 is 240a x 14v = 3360 x.8 for average class d efficency equals 2688w at a heavy clip so roughly 2k clean assuming the rest of the board can handle it. Its also an old used amp with no warranty so $200 is a fair price you could ask $300 but good luck at that price.
Solid audio
Solid audio
Greenville, SC
lsvtec
vegang
vegang
