SOLD FS Soundstream RUB2.250
c_nitty
Item(s) for Sale:SOLD Soundstream RUB2.250
Item(s) Description/Condition:Used like new a few marks on the bottom works great!Specs:power Specifications - Full Range ChannelsRMS Power @ 4 ohms75 watts x 2 channels RMS Power @ 2 ohms125 watts x 2 channels RMS Power @ 1 ohmN/A Bridged RMS Power250 watts x 1 channel Peak Power OutputN/A
Amplifier SpecificationsAmplifier ClassAB Number of Channels2 Total Peak Power OutputN/A Total RMS Power Output250 watts Maximum Input Gauge Size4 Minimum Impedance Unbridged2 ohms Minimum Impedance Bridged4 ohms THD at Rated RMS Power0.015% Speaker Level InputsYes Preamp Outputs1 pair Built-in CrossoverLow-pass (LP)
High-pass (HP) High-Pass Crossover Frequency15 - 225 Hz Low-Pass Crossover Frequency50 - 800 Hz Subsonic FilterN/A Signal-to-Noise Ratio105 dB Channel SeparationN/A Bass Boost0 - 12 dB Bass/Gain RemoteNo Fan CooledNo Fuse Rating30A x 1 CEA-2006 CompliantNo
Price:$75 shipped
sold
item(s) for sale:soundstream rub2.250
item(s) description/condition:used like new a few marks on the bottom works great!specs:power specifications - full range channelsrms power @ 4 ohms75 watts x 2 channels rms power @ 2 ohms125 watts x 2 channels rms power @ 1 ohmn/a bridged rms power250 watts x 1 channel peak power outputn/a
amplifier specificationsamplifier classab number of channels2 total peak power outputn/a total rms power output250 watts maximum input gauge size4 minimum impedance unbridged2 ohms minimum impedance bridged4 ohms thd at rated rms power0.015% speaker level inputsyes preamp outputs1 pair built-in crossoverlow-pass (lp)
high-pass (hp) high-pass crossover frequency15 - 225 hz low-pass crossover frequency50 - 800 hz subsonic filtern/a signal-to-noise ratio105 db channel separationn/a bass boost0 - 12 db bass/gain remoteno fan cooledno fuse rating30a x 1 cea-2006 compliantno
price:$75 shipped
shipping and miscellaneous item information:
item pictures:
(list pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-trader system or less than 10 references that you have sold to in the past. (these must be listed in your signature, or a link provided to a feedback thread listing these references)).
c_nitty
c_nitty
Houston,Tx 77044
c_nitty
