So who is more annoying?
You mad ? //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif:crying://content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif:crying:
He mad bruh.
Naughtyca and that **** c2 threatcon ad it in every fn thread
is it my fault that whatever sub you tries to suggest the C2 Threatcon sub is beefier and cheaper
Threatcon Sub 12" 600watt $129
C2 Audio Threatcon-2
Specifications:
12" Threatcon-2 Subwoofer
600 Watts RMS
Available in Dual 4 Ohm and Dual 2 Ohm
Dual 2 Ohm: Threatcon-2 12d2
Dual 4 Ohm: Threatcon-2 12d4
3" Copper 4 Layer Voice Coil
Double Stacked 160 oz Magnet
High Current Flat Woven Tinsel Leads
Dual Spider Pack
Dual Stitched Non Pressed Paper Cone-
with Mid Excursion Foam Surround
Enclosure Recommendations:
Sealed: 1.0 - 1.25 ft^3
Ported: 1.5 - 2.0 ft^3 @ 35hzSealed: 2.0 - 2.50 ft^3
Ported: 3.0 - 4.0 ft^3 @ 35hz
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
Specifications:
600 Watts RMS
Dual Spider Pack
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
So you know its beefer how? You wouldnt know a real woofer if somebody threw it through your window. The C2 line up reminds me of vvme.
which the VVME actually was good until they raised the prices. not sure why you keep on commenting bad stuff on somethings you have never even tried or used or even seen, i actually have a vvme on my wifes car for $60 it works pretty good.
your just stuck on your name brand and if its not a name brand its not good and yes C2 audio is beefier read the specs
Specifications:
600 Watts RMS
Dual Spider Pack
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
Anyone who argues over the internet once it becomes more than a debate. Especially when it's over whose average car is better. I mean ****, it's all opinion, who cares. But, like I said, informed debate is okay. Just not "Your ******* Taurus has nothing on my Saturn you *****. My mom could **** your car in any race."
i totally agree, people shold just comment on equipment they have used
Specifications:
600 Watts RMS
Dual Spider Pack
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
I don't mind the sub, I think it looks great, but you dump that thing everywhere, that's why people are getting bothered by it. Lay off the paste button and just suggest like I do with Ascendant Audio and my other brand boners.
I agree there. Unless it's a company like Pyramid or BOSS, most people don't use them because it's known that they are awful.//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I actually love for people to use pictures and specs when suggesting, its easier to see and compare, most people we suggest to does not know the equipment we are suggesting and pictures, specs and even videos says a lot just my 2 cents
Specifications:
600 Watts RMS
Dual Spider Pack
T/S Parameters:
FS: 36.7HZ
VAS: 40.9 DM3
QES: .44
QTS: .40
BL: 16.8
MMS: 167.7G
SENS: 91.5 DB
XMAX: 28 MM
Woofer Dimensions:
EXT DIA: 12.48"
CUT OUT DIA: 11.18"
MOUNT DEPTH: 5.82"
You are dumd. vvme is good? Thats why the surronds seperate from the cones. You ask me how I can put down something I've never used, how can you put up something you have never used? I'm not stuck on name brand. I'm stuck on what works, what leads the industry. Its call top shelf for a reason. If you ever tried it you would see my point. Keep shopping in the bargin section where one pant leg is shorter then the other
Lowflyin
Sit on my face, B*tch
Lowflyin
FU JOSE, PA
Slo_Ride
