So, new box in the works for HDS312's
Polar
Just pulled the trigger on the soundcubed's.
Which is the best way to orient them in an extended cab ranger? Id like to have them facing up. thoughts?
I plan on doing a slot port on an end since its probably with in the limits of my abilities unless someone can convince me other wise. I am pretty good at woodworking but by no means professional. Any thoughts on birch, vs mdf vs pine? I really **** at upholstering so its gonna be painted, coated or something on this one.
ROughly the area I have in the back pending me removing the useless jump seats is 20 inches deep at the bottom, 14 inches deep at the top and 40 inches wide across. Im going to try to creat a place other than the box to mount the amps too, maybe underneath the shelf I will have to build to get it to sit properly in the back.
Heres the specs
Model HDS312
Woofer Size 12"
F(s) 33.65 Hz
R(e)
7.39 Ohms
Z(max)
73.74 Ohms
Q(ms) 6.912
Q(es) 0.769
Q(ts) 0.692
V(as) 22.130 liters (0.782^ft)
L(e) 8.62 mH
n(0) 0.10 %
M(ms)
364.40 grams
C(ms)
0.06 mm/N
Sensitivity 1W/1m 82.29 1W/1m
BL 27.20
Xmax 14mm
Magnet Weight 145oz
Coil Diameter 3.0"
Coil Length 40mm
Useable Throw 28mm
RMS Power 1200W
Peak Power 2400W
Mounting Depth 7.69"
Circle Cutout 11.25"
Outer Diameter W/Gasket
12.875"
how does this look?
Height? = 16
Width? = 38
Depth1? = 14
Depth2? = 20
If the above dimensions are OUTSIDE dimensions, enter the thickness of the wood below.
Wood Thickness? = .75
Speaker Displacement? = .4 Ft³
Port Frequency? = 34 Hertz
Port Diameter? = 6 Inches
Number of Ports? = 1
Sq. Port Ratio H:W? = 1: 1
Data Output:
Box Front Angle = 69.4 Degrees
Gross box volume = 4,247 Ft3
Net box volume = 4.055 Ft3
Port Length = 11.755 Inches
Port Area = 28.274 Inches2
Port Volume = .192 Ft3
Square Port Dimensions:
Height = 5.317 Inches
Width = 5.317 Inches
I can do a max 22 depth at the bottom and 48 wide
thanks for all the help stang! Got all the wood rough cut today and ended up with an 8" sonotube. My question now is on finish. I got birch, I really like the way yall's boxes look with it. Not sure how I want to finish it. If i were to stain it, I guess screws are out of the question, Id have to nail it right?
Polar
Polar
WPB, Florida
MrFoca
