So, my HDC3's died....
TrUnK WaNgIn'
Pimp Of The Year
well my hdc3's died about 2 days ago, running two aq3500d's, so now im out to get new subs, ill probably be ordering new subs sometime after christmas, so what im wondering is if i should A. get my 2 hdc3's reconed to aluminum coils, and buy two more aluminum 12's and run four, or should i just go all out and buy 4 copper HDC3 18's, running the 12's is going to cost significantly less, and im sure when i get a dc alt i will be seeing a little more power, do you guys think i have enough power to run 4 hdc3 18's with two aq3500d's at .5 ohms apiece?
well my hdc3's died about 2 days ago' date=' running two aq3500d's, so now im out to get new subs, ill probably be ordering new subs sometime after christmas, so what im wondering is if i should A. get my 2 hdc3's reconed to aluminum coils, and buy two more aluminum 12's and run four, or should i just go all out and buy 4 copper HDC3 18's, running the 12's is going to cost significantly less, and im sure when i get a dc alt i will be seeing a little more power, do you guys think i have enough power to run 4 hdc3 18's with two aq3500d's at .5 ohms apiece?[/quote']
4 18S WILL WORK NICELY ON THAT.
It's probably because you openly use the word "wangin'". //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I told you in your last thread that something was going to go wrong with your amps being electrically starved. I bet those leads on those subs are roasted, due too clipping. HAR !
TrUnK WaNgIn'
Pimp Of The Year
TrUnK WaNgIn'
Knoxville TN
TrUnK WaNgIn'
