so i opened my trunk...
85Caprice4d
only to find 2 ~5" pools of rain water that had been gathering in the holes behind the rear quarter panels. I patched two holes in the rear wheel wells that lead into my trunk...
sadly i think im not going to have a system in this car based on the fact that a few gallons of water + a few hundred watts of power = bad:crap:
sadly i think im not going to have a system in this car based on the fact that a few gallons of water + a few hundred watts of power = bad//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
I believe you need to test this theory and take pictures/vids of the results
Caprice? Look at the body seams on the sides where the seal goes around. I had to fill mine with seam sealer. Its a common problem, thats why it rots out down in the quarters.
i will go take pics of said holes. and yes you are right, it is dripping pretty bad with a steady stream for the passed few days in the rain //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Take you seal off, youll see the seams, they are on the sides and 2 up near the back window iirc. Clean it up good, go to an autoparts and get some seam sealer, its in a tube like caulk, like $15 or so. After I fixed mine, no more leaks, even after beatin it with 1600w and 4 12's for a year or so
You should bondo that hole with like some fiberglass too
85Caprice4d
85Caprice4d
Milwauke, WI
Blazin_Jason
