that meant your port was 2inches taller too wasn't it? This box is for 2 15's right? Anyway if you can download some tones mess with it. Play tones up high at like 40hz and notice how things get louder as the volume goes up. Then try some tones alot closer or at tuning. You'll probably find that those tones dont' scale up as nicely and at a certain point, much earlier than up higher, they begin to simply not increase in volume as quickly. That's because at tuning the subs arent' providing any output, the port is doing most of the work. A little 3x15inch port trying to move enough air to make a 25hz tone loud isn't going to cut it. As you go down in frequency you need to move more air to keep the same SPL. That means that to get high SPL's at tuning, especially down low, you need a big *** port. Try at least a 4.5" port next time using your old height. Design the box backwards. Shoot for giving 2 15's about 2.5 cubes net. That'll be 5 cubes. That leaves you with a 1.5 cubic foot port. That ends up being 28 inches of length if you make it 4.5wide at 17.5 tall (19inch tall box) That'll be around 34hz tuning. Put it close to the hatch and it'll go lower, probably 32-30hz tuning. It wont' compress as much though so you'll probably get more output overall, especially in the lower 30's late twenties, which is as low as almost anything goes anyway, even the c+s stuff is like 25 at the lowest usually. IF you can invert mount the subs, that'll give you a few more inches to add lol.
