So I got this cheep little...
Techchild
Not a racist.
DMM it has no intructions. How would I go abought setting it up so I can do my gains with it?
I'm to lazy to look but AC 200 is what I believe you want on the dial, I bought an auto range one so I only kinda remember when reading on this forum in the Gain sticky.
Get a clear shot of the 3 connections at the bottom.
One is common (ground)... can't remember the other two's labeling.
I think one is for a lower range and fused and the other is a higher range and unfused? Or something like that? I am probably better off not answering but I figure I might try to help, I am a noob too. lol
alright the ac 200 cool.Also what hz test tone should I use to set my sub amp gains?
Good Question, I've heard some people use 50hz, I used 30hz since that's what my box was set to, what kind of box do you have?
Shoot, I have no clue since I'm fairly new to this tuning stuff, I know I read a suggestion where it said to use 50hz for Subs in general but maybe someone else can chime or point you in the right direction.
Nice system!
Nice system!
Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
50 or 60hz is generally used because its right in the middle of the common "sub" range. Too low and you could be running into the SSF, and too high and the LPF could effect the voltage readings.
Techchild
Not a racist.
Techchild
Middle school locker room
ARSkemp
Mike Mccabe
