so i got some 4/0...what fuses?
vickman08
i just need to know what size fuses to get(or circuit breakers,which ever one is better)what size they should be, and where to put them...do i put them before the main battery only?or before the main batt AND before the both secondary batts?is it ok for me to run my stock batt with my 2 c&d batts? also is it possible to make ur own distro block, or does anybody know where to get one that will fit the 4/0....can i use this for the ground too?when wirig batts do it ground to chassis or to batt itself... could someone link me me to some pics of the wiring of batt
heres list of my equip
alpine 9813
4 id oems
1 pg xenon 200.4
1 ia 40.1 wired to 1 ohm
2 05 xxx 15's(d4)
2 c&d batts(100ah ea)
please help me asap as i am awiting responses so i can start wiring the batts up...(only thing i have not done before)will paypal someone $5 to completely diagram the the wiring process in paint shop or something
http://www.powerstream.com/Wire_Size.htm doesnt matter want the amp needs, you fuse to the wire: says 380Abut @4/0 can vary quite a bit due to strand count and quality of material..just read that its going to be rather short run of wire, but still a fire would probably ruin that $1000 amp you have..
oh yea?try running 4kw @ 1ohm on 4G with a 100 amps of fusing //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
ya i got 4/0 flexaprene welding wire not 4 ga....so i should 380 amp fuses? is so how many. nad where do in find those fuses?
i was talking to the other poster questioning my answers.check my sig,i have more 4/0 in mine than most have 1/0 and i run no fuses.//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
on yours i would start with 300 amps of fusing.
vickman08
vickman08
fort knox
SicAudio
