The only thing I would change is the baffle. It should be mounted to the very top edge of all the pieces on the box, as in lay it on top of box and screw it down. On 2 sides you cross drill/screw into it. From a stress standpoint, that design is weaker, it transfers much of the weight directly through screws. If the baffle sits on top of all 4 walls, it transfers weight evenly and straight down through the 'leg' walls, to the floor. It is also probably the reson for your leakage problems... not to mention makes it obvious you only did a single wall baffle. tsk tsk //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Screw another baffle board to the top of that (with the speaker cutouts obviously) and I think you'll be golden. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
