Sold Smokin Deal right now right here
Street DreamsCC
I have 4 JBL Crown 6000GTi amps from my SPL van. These are by far some of the best sounding and cleanest sounding amps I have ever had the pleasure of playing with. These are well worth every penny.
VERY RARE you cant find alot of these anywhere. You can be one of a kind in your area. Excellent amp for street classes and even daily.
from JBLs website these ratings are RMS
Output Power at 14.4V and ≤1% THD+N (CEA-2006):
2 x 2600W @ 4 ohms
1 x 8110W @ 4 ohms
1 x 7400W @ 1 ohm
S/N Ratio: 65dBA (1 Watt, 4 ohms)
Effective Damping Factor: 6.39 @ 4 ohms
Freq. Response: 10Hz ∼ 270Hz (-3dB)
Fuse: 600A internal (external 500A minimum)
Dimensions: 29.38" x 23" x 6.5" (74.6cm x 58.4cm x 16.5cm)
Weight: 88 lb. (40 kg.)
This mono amplifier has +/-165 Volt DC rails that power two 3 KW BCA (balanced current amplifier) half-bridges.
This allows three modes of operation:
1. Two high-voltage amps each driving 2-4 ohms with 160V+ peaks.
2. A single bridged output driving 2-4 ohms with 320V+ peaks.
3. A single paralleled output driving 1-2 Ohms with 160V+ peaks (patented).
http://www.jbl.com/car/products/prod...at=AMP&ser=GTI
http://ampguts.realmofexcursion.com/JBL_A6000GTi/
6000-Watt Balanced-Current Subwoofer Amplifier With Current Servos.
Built-in variable electronic crossover with selectable slope rate.
Dynamic Bass Optimization (DBO) - This provides variable filtering with adjustable "Q" below 100Hz, far beyond conventional "Bass Q" circuits, by allowing the low-frequency output to be optimized for specific subwoofer applications. Frequencies below an enclosure's tuning frequency can be attenuated, preventing damage to the subwoofer and allowing the amplifier's power to be better utilized.
Variable phase control
Full-range preamp outputs - In the event that multiple amplifiers are used in an application, this feature allows for streamlined system hookup. No high-loss Y-adapters or splitters needed.
2 have casings $1600ea plus shipping and crates
2 without $1350ea plus shipping and crates
Pickup is always welcomed. All have been tested and were just used and puleed a 161.3dbs certified on a termlab on a 14v system.
I would Greatly appreciate picking up but shipping is possible. Located in Niagara Falls, NY so you could plan a minor vacation to here and grab this on your way.
Sorry but NO trades unless it is for a SD 8000.1
sick power and cheap too. These are alot better built then alot of the korean amps. VERY dependable. Ask any owner of one of these if they ever blew one, 99.9% will tell you NO.
I had a sub go on me which would normally take out an amp..........nope amp worked flawlessly. These are top quality amps and you will love owning one. Its like nothing you ever had before.
Street DreamsCC
Street DreamsCC
NEW YORK
Street DreamsCC
