Small sealed box for An Eclipse 12" TI
SlickCMRick
I'm going to be getting one of these soon hopefully and I'm looking for a nice sealed box. I hear they work best in small sealed applications. Wattage will be 1100RMS from a Lanzar Opti2000d. Anyone have experience? I was thinking 0.55 , 0.75 cubes, or maybe even 1 cube
I just saw this ported box and im really considering it
http://www.caraudio.com/forum/showthread.php?t=147316
Fs 27.676Hz
Vas 32.4L
Sd 430cm^2
Qts .328
Qes .351
Qms 5.00
Znom 8 (series)
Revc 5.9 (series)
Xmax 23.15mm
Bl 28.00Tm
Pe 1000Wrms
Max height dimension is 14" high.....
specs:
RE - 3.1 ohm (each VC)
FS - 27hz
qts - .30
vas - 3.2 ft^2
spl - 89db
qes - .32
qms - 5.0
sd - 490 cm^2
xmax - 38mm
woofer displacement - .19 ft^2
nG
i was looking for SQL when browsing for my box, and someone recommended 2 cubes at 34hz. so, that's wut i'll recommend to you. i believe the Ti would be very responsive in about any size box you put it in. but if u want it loud, i'd do big and ported.
Ok because i listen to only RAP music......i wanna grab those lows
1.75 ft^3 net tuned to 35Hz with atleast 25-30 in^2 of port area. What about that!!
SlickCMRick
SlickCMRick
Las Vegas
iamamp3pimp
