Small Problem!
shawnohio
I have alittle probably and was trying to get some advice before i built my box. My Problem is i have a 99 grand am(peice of shit)and i am trying to fit a 4cube box tuned to 34hz for 2 type R 12's. If i build it the way i have it drawn out with a depth of 23'' it is going to put my sub only about 4-5'' from the end of my trunk. I was just wondering if that would effect the proformance in anyway or if i should scale the box down. I will also be using fatmat in the truck.not sure on the thickness but might make it closer to 4''.
Shawn
i went back out and checked some mesurments and i don't think i will be able to get the box in.
how do you think they would sound if i gave them 3.5 after all displacement @34
do you think that .5 will make much difference or should i try to build the box in my truck lol=)
the box in the trunk of my 2001 grand am is 36 x 15 x17.5 and it fits in there just barely. had to removie the spair tire to put it in then. and then after the box was in i was able to put the spair tire back it
I think i have figured something out but wondered if someone could check some number before i build. was plaing to build today.
Trying to get 4ft @34Hz after displacement
Sub Displacement - 0.128(I think, type r 12"
External
W - 37.5
H - 16.5
D - 19.75
Port Width - 4.5
Port Length - 32.5
Port Area - 67.5 sq in
Thanks,
Shawn
shawnohio
shawnohio
East Liverpool, Ohio
j3bus2k3
