Small enclosure sub
Brandenton
SPL IS GOOD!
Trying to get some suggestions on a good sub for a small sealed enclosure. I have two 10in memphis power reference subs and they don't sound so good in the enclosure they are in. Looking for a sub with a rms of at least 350 watts. Thanx!
assuming your looking for more of SQ with that small of an box, check out the ID10v3's. sounddomain had them for $80-+ shipped with warranty but it looks like their out of stock. you can try emailing them to see when their next shipment will come in.
http://www.cardomain.com/shoplist~b~Image+Dynamics~t~Subwoofers
I'm not looking for SQ, i just dont have space, i want a sub for SQL, that works well on small enclosure, first i'll put it on a sealed cause of time for building, but i will be working as i could on the fiberglass aplication that i want it'll be about 1.1-1.25cuft ported, that's why i need a good sub that can get loud on small enclosure with the limitation i put up.
Thanks
If you could get ahold of an older Boston Pro that would suit your needs very well. I have one in a 12'' version and all it takes is a 1.0 cu sealed box and it has great response. The 10'' needs only .5cu sealed I believe. Great sounding subs too.
Brandenton
SPL IS GOOD!
Brandenton
Hapton
superdooperman
Mike Mccabe
