I also want to keep everything under the window line though....on 2001 tacoma's the side windows in the ext cab area are 5.5" lower than the back windowYou could do three and run the amp at .67ohm. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
And your PM's are full. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifyeah....6 rli-8's on a 3000dtuned at 32hz
I'm always thinking about a new setup...hahawere you thinking about getting a different set up?
Just realized that....clearedAnd your PM's are full. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
1 sub, 2 sub, 10 subs? Enclosure specs? Power? TL? Not saying you're lying but your comment was so vague that it's difficult to use for comparison.go with the skars 1 guy was going 149 on music
Probably Anton over on SSA. Same guy that did the 148 pre-break in. If so, 2 12's in 5 cubes @ 28 hz. Putting up the numbers under 34hz....Sealed off Cavalier.1 sub, 2 sub, 10 subs? Enclosure specs? Power? TL? Not saying you're lying but your comment was so vague that it's difficult to use for comparison.
sig ftw! //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gifprobably anton over on ssa. Same guy that did the 148 pre-break in. If so, 2 12's in 5 cubes @ 28 hz. Putting up the numbers under 34hz....sealed off cavalier.
