Skar vs Taramps vs Kicker monoblocks?
The MD is the replacement for the HD line.
MD has a flatter FR
Power rating is at a lower frequency.
Power rating is at 12.6 volts
Rated power is at 1% THD
Fully insulated inputs and outputs
Better protection circuit
Board layout is different.
MD has a flatter FR
I will let everyone know how it works out when I get it hooked up.
I watched a video last night that showed a HD version completely fried. But he was running two 18s.
I am hopeful running my single 12 won’t cause any issues. I am running 0 gauge wire, so I should be okay.
I have had 10 Taramps amps. From the T20.2kw to HD3000 - DSP3000 - HD10000 - TS 4 channels ETC. Never had a problem with any of them. Most of the negativity you hear about them online is from people who have never even owned one and just spreading the same ole "mY cOuSiNs NeIgHbOrS cAuGhT fIrE".
Why do they have the “bass” line? The price per what is significantly higher then even Korean boards
Bass line is can run .5 ohm and even .25 ohm. Much more beefy internals.
Price per watt is much cheaper than most Koreans.
Sundown SAE-3000 - $750
Crescendo Symphony 1500 (Chinese)  $314
Taramps Bass 3000 - $280
Bass 30k. $2500 for 30k+ watts rms.
The Bass 8000 will be out soon and I think its going to be very popular.
585
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
934
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
jeeper2269
jeeper2269
Somewhere, OR
    May 12, 2024
Brendon Jenness
    May 11, 2024
