Skar SK-125.4D $250 shipped
Skar SK-125.4D
Works and looks great. 9/10
SK Series 4-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 133 watts x 4 chan.
2 ohms: 204 watts x 4 chan.
Bridged, 4 ohms: 396 watts x 2 chan.
Pulse Width Modulated MOSFET power supply
Wired remote bass level control included
LED power (green) and protect (red) indicators
Soft start turn-on
4/3/2 or Mono channel operation
Preamp RCA outputs to daisy chain multiple amps
3-way protection circuitry (thermal, overload, and speaker short protection)
Heavy duty aluminum alloy
Input sensitivity:
Level: 200mV-6V
Variable high-pass filter (50-500 Hz with 10x multiplier, 12 dB/octave)
Variable low-pass filter (50-500 Hz with 10x multiplier, 12 dB/octave)
4 gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits from our website when purchased together with this amplifier.
Dimensions: 7-1/2"W x 12-3/4"L x 2-1/16"H
$250 shipped to lower 48
shipping included
Will trade for 2 Faital Pro 8PR200's. Has to be exactly those to match my other 8's.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
673
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
THUMOS
THUMOS
Palmer, TX
THUMOS
