Skar Audio VVXv2 Series Box Designs & Cut Sheets
SkarAudio
Today I put together box designs along with cut sheets for the VVXv2 Series Subwoofers, in both Single and Dual Woofer Designs...
If you are looking for a strong and great sounding enclosure for your VVXv2 woofers, these will be perfect depending on how many and which size woofer you are running as they were designed specifically for these drivers =). Simply browse the designs below and click the associated link for the PDF File which will give you the cut sheets as well as other specifications. These boxes are relatively simple to put together if you have the basic tools required and are clear cut so as not to be confusing how to assemble.
All designs can be found at Skar Audio - Where Audiophiles Meet Excellence > Knowledge Base (Footer Link) as well as in this thread..
We will be coming out with designs like this for all of our different woofer lines specifically for each series, so stay tuned if you have other Skar Audio speakers.
Single VVX-10v2 Ported Enclosure Design & Cut Sheet (PDF)
Dual VVX-10v2 Ported Enclosure Design & Cut Sheet (PDF)
Single VVX-12v2 Ported Enclosure Design & Cut Sheet (PDF)
Dual VVX-12v2 Ported Enclosure Design & Cut Sheet (PDF)
Single VVX-15v2 Ported Enclosure Design & Cut Sheet (PDF)
SkarAudio
SkarAudio
Florida
SkarAudio
