The crappy meter is going to meter higher than a TL, in most cases. Usually a TL is the hardest to get a good score on, because it's actually accurate when calibrated correctly.It was probably a crappy meter ill see if I cant rent a term lab here in town.
Yeah, I thought id score higher tol, it was rainy/wet out does that matter.The crappy meter is going to meter higher than a TL, in most cases. Usually a TL is the hardest to get a good score on, because it's actually accurate when calibrated correctly.
Guy said he used his usb SPL Meter.The crappy meter is going to meter higher than a TL, in most cases. Usually a TL is the hardest to get a good score on, because it's actually accurate when calibrated correctly.
How much would it cost to rent a termlab from Custom Concepts?Guy said he used his usb SPL Meter.
$30/half hourHow much would it cost to rent a termlab from Custom Concepts?
I'm interested in seeing what numbers my SA12's can hit.
Would've been cool to go to the show in 'Nona, but I worked all fuggin weekend haha
You're telling me bro, I'll be adding a second VVX15 then adding another SK1500.1 strapped.damnn that score blows
I'm really not sure you'll need that extra SK1500.1. With even 1000rms each they'll be fairly close to their limits surely? Giving them more sounds like a recipe for disaster. Could throw an 18 in that box, considered that? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifYou're telling me bro, I'll be adding a second VVX15 then adding another SK1500.1 strapped.
On the 1680 @1ohm before rise this subwoofer takes it like a champ, I wouldn't be surprised if both subwoofers could take 2 SK1500.1's.I'm really not sure you'll need that extra SK1500.1. With even 1000rms each they'll be fairly close to their limits surely? Giving them more sounds like a recipe for disaster. Could throw an 18 in that box, considered that? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
didn't realised you had this gained to take the full power of that SK1500! That's awesome man, would not have expected that, especially in a box of this size. In that case by all means throw another amp on two 15s.On the 1680 @1ohm before rise this subwoofer takes it like a champ, I wouldn't be surprised if both subwoofers could take 2 SK1500.1's.Plus SKAR has yet to release their 18" (once the 1500watt line is released there will be)
Well there was some discussion of it being too much power/bottoming out/unloading etc, well on full tilt, there is no sounds of bottoming out, nor any mechanical noises, subwoofer does not get warm at all, no smells etc.didn't realised you had this gained to take the full power of that SK1500! That's awesome man, would not have expected that, especially in a box of this size. In that case by all means throw another amp on two 15s.
That's ideal hahaha. Can't get my head around that meter reading then, needs to go on a TL for sure.Well there was some discussion of it being too much power/bottoming out/unloading etc, well on full tilt, there is no sounds of bottoming out, nor any mechanical noises, subwoofer does not get warm at all, no smells etc.
We'll see where this goes after adding that second 15, then after that snag a second SK1500.1 should be quiet.
Yep, I'll post some more results in the future.That's ideal hahaha. Can't get my head around that meter reading then, needs to go on a TL for sure.
