SK-1500.1 strapped output @ 4 ohms?
why would you strap @4 ohms each amp will be running @2 ohms sp id say 16-1700 between the 2
I can only load 1 or 4ohms being a D2. I dont want to risk having space heaters by running 1ohm
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
351
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
587
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
945
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
846
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
JoeK
JoeK
Ringtown, PA
BrownVanMan
    May 18, 2024
    May 18, 2024
