Single Yellow top with LARGE amp
danpenksa
I have an Optima Yellow Top under the hood that I will be using for a 2600 watt RMS amp (Stetsom 2k6) and 3 JL 300/2 amps...I also have a Mechman 250 amp alternator...
Will I be OK...Adding additional batteries is absolutely not an option...I don't necessarily plan on competing, but generally listen to my music fairly loud...
THANKS!
dan
so considering I have zero room to add any more batteries, I should probably scrap the idea of this working? //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
dp
dp
no, you cant fit a 3.5" x 6" x 5" battery anywhere? (batcap 800)
dp
there has to be somewhere what kind of vehicle you working with?
scion xb....the trunk is absolutely tiny, and Im already throwin a 3 cub box in there, the three jl amps, the stetsom--i cant use my spare tire well or the cabin anywhere (I log major miles for snowboarding trips--it is my primary concern that all audio gear is soley in the trunk area)
dp
dumb question, but how do they wire up...are they safe to just sit on carpet...
dp
positive on your optima to positive on the batcap, same with negative, or you could just ground the batcap directly to the frame instead of running a positive to it also.
yeah, they are a sealed battery like the optima, you can mount them in any position.
can you mod the area under the hood to have one big battery like a d3100 or kinetik 2400? with that big of an alt, and the big 3, you should be ok with an efficient amp like that.
danpenksa
danpenksa
Las Vegas
dtbrown
